yazoo mower blades
danielbme
I have a 20"big wheel yazoo but can't find a replacement blades.Part numbers are yazoo 206-620 or primeline no. 7-06781
Boobala
Probably do better if you supplied the Yazoo MODEL numbers ......:thumbsup:
Seems like I got a blade for a customers S20 last year. I think it was from Rotary. There website is down for maintenance so I can't check right now.
63maxcruise
I know this post is very old. You can try a Yazoo 206-660 blade. This is a 20"blade from the 60"cut mower and it's still readily available. It's a little longer than the 20" push mower blade so you may have to grind or cut approximately 1/2 inch from each end
