ProMower
- Apr 16, 2016
- 4
- 26
Working on a Yardworks Powermore that was working fine and then just stopped, nothing was hit. New spark plug (BPR6ES), has spark, fuel is clean, carb is clean, has a primer bulb which primes, brake cable is good, flywheel key is good, blade is good, pretty new mower really, good compression, valves are working as normal, hit it with starter fluid or prime and does not even try to start. I am out of ideas. Let me know if you have any good ideas.
Tks
John
Tks
John
