hello there,
A few weeks ago I lent someone my yardman (model 13ao771h055) and they put a hook attached to a tow rope in the opening just behind the battery because it didn't fit into the tow point. Anyway the actually hooked the wiring harness as well. When they made a left turn the hook came out of the hold and they were towing by the wiring harness. wish they hadn't shut it off out in the field; had to push it all the way back.
The only thing I can see is that a green wire that comes out of the harness was pulled or broken. The problem is I cannot see from where. See the photo, but the fuse usually sits about where it is in the photo and that wire doesn't easily reach the solenoid (?) and I can't see where it would go into any of the safety switches (it won't even reach). Maybe the wire broke twice so isn't as long as it should be?
I tired searching for diagrams and they only thing I could find is a wiring diagram showing a green wire going to the battery ground wire where it attaches to the chassis. In this case I guess that would be bolt that attaches the solenoid to the frame, but when I removed that bolt to get a good look at the solenoid I didn't see a connector or even a remnant of wire.
Anyone that could help me I would greatly appreciate.
yes, the mower looks like it was rode hard and put away wet. It's been used HARD and until this happened worked fine. It spent 10+ years mowing and pulling around a brush cutter over rough country yards and fields. You can see the welds I made the first and only time I used a welder when the brush cutter started actually tearing the frame box - might of hit a few or a hundred trees while mowing in the tight places. I know it's kinda startling when that tree jerks the mower to a stop. Dang thing keeps going though! $900 and 12+ years later I think I got value for money. It mows where I'm afraid to take my $3K cub cadet.
TIA
Boardbum
TIA
Boardbum
