Yard Machines electrical issue
mikehenya
I just purchased a used Yard Machines 13B2775S000 and it appears to have an electrical issue. The terminals are clean and the battery has a full charge. Yesterday when I bought it, it started fine. Went to move it this morning, turn the key and no noise, no clicks, nothing. The battery is still fully charged. Starter seemed strong when it did start
Not sure where to go next, thoughts?
Thanks
dougand3
Brake on? PTO off? Sitting in seat? Those are your 3 safety switches - one could be intermittently flaky.
Ignition switch could be flaky.
mikehenya
Sorry, I should have mentioned the Brake, PTO and Seat switches are good. I'll look into the ignition switch.
Has anybody considered checking the fuse. Should be located near the battery area. MTD likes to hide them sometimes, so may have to look for it.
