- May 6, 2010
- 12,037
I have a friend/customer that has the above engine on his Bad Boy mower. The issue is when his son uses it to pull the boat trailer around it sets off a issue with it running rich and blowing black smoke. There is a manual sequence to re-initializale the system that basically remaps the setup to make it run correctly He had the procedure printed out but has now lost it. And we don't have any close dealers to see if we can get a new copy of the procedures.
It sounds like a procedure similar to what was done with the Kohler TPS reinitialization when changing the battery or installing a new engine. Does anybody have the steps to reset the system.
