DeSotoDixieChopper
- Jun 13, 2020
- 1
- 2
Hi all,
Apologies if this has been asked already. I searched but didn't see an answer. I have an XXW4000 built in the year 2000. On the bottom of the wheel motors is a 90 degree fitting. Some one (probably me) replaced the bottom of the four socket head cap screws with one that was too long and it bent that 90 degree fitting. Now it leaks hydraulic oil.
I need to replace the fitting but can't figure out how to remove it. It's too long to just unscrew and I can't figure out how else other than removing the wheel motor itself. So, how do you do that? Do you have to remove the four bolts on the inside of the wheel motor to take it apart? How else do you remove one of those wheel motors? It seems that with the 90 degree fitting attached, you aren't getting the wheel motor out. Please help!
Thanks!
DeSoto
Thanks!
DeSoto
