can anyone tell me where the ground cable from the battery hooks to the mower. thanks
B basstracker Active Member Joined Jul 9, 2013 Threads 19 Messages 51 May 27, 2023 / x520 jd ground #1 can anyone tell me where the ground cable from the battery hooks to the mower. thanks
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Threads 64 Messages 24,702 May 27, 2023 / x520 jd ground #2 JD like to mount the ground wire to one of the engine mounting bolts 3 are the normal acorn bolts and one of them is a standard bolt with 2 nuts . one to hold the engine down & the other to hold the ground strap .
