Worn out (apparently) Craftsman selfpropelled 6.5hp mower
carpetmaster
  • / Worn out (apparently) Craftsman selfpropelled 6.5hp mower
I have a 8 year old (approximately) 6.5 hp self propelled Craftsman mower that "kicks back" violently when I try to crank it. I hit a stump with it a month ago and bent the blade very bad! I replaced the blade and saw no evidence of shaft problems as the mower cranked and mowed as before. any suggestions? The upper frame is rusted through in a space about the size of a golf ball. Should I just I purchase a replacement or try to get this one through the summer?
Briana
Welcome to LawnWorld!
We moved your thread to the Craftsman forum.
Most likely issue is an offset or sheared flywheel key.
D
DJlawnboy
Guest
Just bite the bullet and new a new mower...this one sounds pretty bad.
