Will not start. Pull handle no pressure.
mrdibs
Hi; Had mower on barrels. When taking off barrels, it fell. Now when I pull the start handle, blade spins,but does not start. No pressure on pulling handle. Has anything come loose? Comments? mrdibs
lewb
pull plug and see if you have compression, if not you may have broke piston from connecting rod some how.
bwright1818
That's a weird one. Why was it on the barrels? Were you working on some kind of problem that may be related to this?
