Question, why do you have to replace the crankcase bolts on a V-Twin when you open the engine? Why can't you just wire brush them and use tread locker on the old ones? From what I see is that if the treads are good and clean you should be able to just use a good tread locker and torque them are usual.
Budd
Budd
