- Feb 19, 2020
- 45
- 7,318
Boy this irritates me. Local shop has a rookie tech that is just guessing at what is wrong with things and don't even have the proper tools or is too lazy to use them. But what do I expect from a so-called professional shop.
The first I got in from this shop was Hustler with a 35hp Briggs. They told the customer he needed a new $4000 engine. The problem was it was consuming oil like lazy but the mower was able to cut 3+ feet grass like it was a normal lawn. What I found was just a blown head gasket. When the customer went back they said no way that was the problem and yet the customer has been using the mower for now over one month and barely has to add oil. He is a commercial user.
Now Saturday I get in another Briggs 13L engine that had been the same shop three times for carburetor problems. The root cause was trash in the fuel tank. Even after a tank cleaning, three supposedly carburetor cleanings and a 70 micron fuel being added the customer was still having problems. Well I torn the carburetor to find the main jet and the inlet clogged with large pieces of grass. Apparently the fuel line was never cleaned out or the was never fully cleaned. What worst is the tech instead using a 4mm socket to remove the carburetor used a pair vise grips. And then when he tried to remove the main fuel nozzle use a plain common flat tip screwdriver screwing up the nozzle. This part is not replaceable as Briggs does not provide it. Beside the carburetor repair kit cost nearly as much as the carburetor itself so best to just replace it when necessary. Boy Brigs has gotten proud of their carburetor repair kits.
On top that the breather tube was broken and split he just RTV that problem. And he had disconnected the kill switch because of a supposedly fail oil level sensor. I didn't verify the sensor but I did reconnect the kill switch and properly bypass the oil sensor system. The customer was much happier with the engine shutdown having to wait the carburetor to run out of fuel.
Now I am having to wait for a new breather tube as it is the first I seen this particular so I had none in stock and Briggs Power Distributor is out of them (B/O). I found one on the West coast so it take a week to get here. Meanwhile I adding a couple to my stock order and order once Briggs gets them in.
Sorry just had to vent a little.
