Fuel Where does the fuel line connect to the engine?
its
Is there an engine or fuel line diagram somewhere that I can refer to for my Honda Lawn Tractor H4518H? The owner's manual does not show the engine connection.
I had to replace the battery and must have knocked the fuel line loose from the engine. The one end is still connected to the carb, but I don't see where the other end belongs so I can re-attach it.
Any help would be very much appreciated!
Thanks!
exotion
Start at the gas tank should connect from tank to filter to pump if it has one then to carb
tds19
yes. fuel moves from the tank to the engine via the carb. follow the line from the tank.
robert@honda
Thanks!
From what I can see in the shop manual, there are three tubes connected to the carburetor. The fuel line itself (pink), an air vent tube (green; loose/open on one end) and the drain tube (blue; connected to the bottom of the carburetor). Here are few images that might help:
