I reserrected a 1994 over one winter and it is running perfectly. My problem is the mower CUT is terrible it leaves riges and the lawn looks like heck!
I found that the front wheel on the left side and the rear spring loaded one on the same side are worn excessivly obvious just to site. It appears that the entire weight is on the left side. This is opposite to the side where the deck lifts from. I have made as much adjustment as the deck allows, but to no result. It seems the deck is riding on the left side and not normalizing position when lowered.
Is there a typical problem with these models because the deck is lifted by an off center location?
If any of you have experienced this please help me out. It is a 38" deck.
Reed
Reed
