Whats wrong with this briggs 33r8 77 0004? Video included
RepairmanJake86
  • / Whats wrong with this briggs 33r8 77 0004? Video included
What's up fellas? Trying to fix this D110 with a Briggs 33r8 77 0004 19hp single cylinder. The throttle linkage is ramming back and forth like crazy Is the governor broke? I thought a rod or valve was busted when I heard it the 1st time, but the valve cover is sealed on with gasket maker and before I check the valves,, I want everyone else's opinion.. I've got great compression and no leakdown. Carb is spotless and fuel pump good.
It is surging the 100% most common problem
Usually fixed by removing the carby then a full strip down with a proper clean .
When doing that you have a close look at what you find inside which can indicate bad fuel lines .
After that debris i the fuel tank blocking off the fuel supplu
Water in the fuel filter which does the same
Collapsed fuel lines
Blocked tank vent
Scrubcadet10
Moderator
Staff member
Does it smooth out with choke?
if so, then what Bert said.
