Whats the part number?
davbell22602
Can anybody put part numbers to this exhaust pipe and muffler?
Dave you oughta know from your days over on ppeten that we need the equipment numbers.
davbell22602
Equipment numbers don't exist cause I bought inventory from a shop that closed up
Was it a dealership? If we knew what brands they had, would give us a start where to look.
On the muffler try Kawasaki part number 490706001, looks similar. Do you think the manifold and motor muffler go together? How is the muffler mounted?
davbell22602
Kawasaki offered muffler kits on some engines where you get pipe and muffler. But never got close enough with the exhaust pipe. I come close with kohler on exhaust pipe and kawasaki on the muffler.
davbell22602
Muffler on that part number has 2 holes on the bracket and pipe on muffler is hair off. My muffler has 4 drilled holes on bracket on muffler and pipe on muffler has 90 turn then comes out straight hair and no heat shield. It's possible it's the right muffler and kawasaki redesigned the muffler to fit better
