What type of MTD do I have
Lister
I have this MTD lawn mower, it is a transmatic. The ID plate is gone and I have no idee what type and year it is.
I need a set of belts for it but do not know the right numbers.
Who can help me :unsure:
regards Lister
Scrubcadet10
Moderator
Staff member
I assume you looked under the seat for the model sticker?
Post the model numbers from the engine. I will help narrow down the year of the mower. and in some cases MTD listed the engine info on the mower model number lookup on the dealer site.
Lister
Where do I need to look for the numer on the engine?
Lister
I forgot to mention that I found a number on the rear axle, it is 717 761. Does that help?
Scrubcadet10
Moderator
Staff member
on I/C engines, they is usually a tag Riveted to the blower housing near the spark plug, or a corner of the housing on top.
upupandaway
Maybe for the newer models Scrub. On my 12I/C which is likely from the ballpart as posted, the info is stamped into the cover just above the spark plug.
Scrubcadet10
Moderator
Staff member
Maybe for the newer models Scrub. On my 12I/C which is likely from the same time as posted, the info is stamped into the cover just above the spark plug.
One now has a riveted tag from 1998.
