what is this part? Leaking oil??
geelee
that is a pulse fuel pump, if its leaking oil out of the brass breather you are overfilled with oil or have excessive crankcase pressure due to a bad headgasket
kens68charger
Thank You was there any damage "if" I over filled oil??
Well not really. But with a blown head gasket which is common on these engines there is a good chance running the engine without oil which will destroy the engine if not caught in time.
geelee
no damage just drain some out. be sure to check if there is gas in the oil causing it to be overfilled. you can smell it on dipstick and with a match the oil on dipstick will light up. if it does you need to change oil and repair carb.
kens68charger
Ok One more question, I want to replace the part thats leaking..in the photo above (after I drain oil) Im not finding the exact part number thats stamped on my part 808482 Im finding what looks to be the same but #808656 is it the same part???
geelee
need model and type numbers off engine
geelee
33r877 0003-g1 is your model and type 808656 fuel pump superseds to 597338
