Model No. Tnt 100-10079d Do I just set the gap when the piston is TDC?
B bluefitness Member Joined Sep 16, 2012 Threads 13 Messages 46 Sep 21, 2020 / What gap do I set the intake and exhaust valves to? #1 Model No. Tnt 100-10079d Do I just set the gap when the piston is TDC?
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,760 Sep 21, 2020 / What gap do I set the intake and exhaust valves to? #2 Intake .004. Exhaust.008. I recommend setting them 1/4” past TDC.
cpurvis Lawn Addict Joined Aug 25, 2015 Threads 21 Messages 2,256 Sep 21, 2020 / What gap do I set the intake and exhaust valves to? #3 There are TWO TDC's--One is when the exhaust valve has just closed and the intake valve is just opening. You do not want to set the valves using THAT TDC.
