what are these called?
JGGMC
I was mowing without the spindle covers on and lost the wing screws that hold cover on. I want to know their name to look up them on ebay. I avoid the dealer whenever I can. I have a Tiger Cat 2
Parts tree .com is a great source for schematics & OE parts as well.. Just sayin,..
Its Me
that is the first thing I take off, the grass collects under it and have to remove to really see that the check valve is working proper when you great the spindle, makes cleaning easier.
If there are no kids using the mower & you can train yourself to always enter and exit over the front of the mower and the set switch is operational then by all means take them off.
I regularly cut holes in them for customers to prevent grass accumulating under them or make them easy to clean out with a leaf blower.
Not as much of a problem with ZTRs as it is with tractors .
Lots of nasty injuries from feet and spinning pulleys coming into contact with each other particularly on decks over 40" wide.
Rocky J
I grew up calling them wing nuts, Parts store are around 50 cents each 1/4 inch nc thread
