PTmowerMech
- Apr 16, 2018
- 255
- 1,656
BZE6026KO came in with electrical issues. Someone had changed a bunch of stuff up, after the new solenoid didn't work. I think it was just the starter was bad. But they changed the solenoid, tied some wires into other things. And it was a mess.
I've got it down to where it cranks, runs and charges. Except THE only way this is possible, is for a pretty thick black wire, that has power going through it when the key is on, to be grounded. I have it grounded to the bolt that holds the 4 post solenoid to the frame. If this wire isn't grounded, nothing happens at all.
The wire doesn't have the OEM end. It goes from the solenoid all the way back up to the other end of the wire wrapping, then what looks like to be back towards where it came from. But lost in the harness.
