justinosssss
- Mar 30, 2022
- 1
- 1
Hi, hope someone can help.
Parked up my 2008 T1800 back end of last year, came to try and start, and the machine is dead. The battery is good as it has been on a maintainer, and I also swapped the battery off an older T1800 that easily spun over that mower when I tried it.
What happens, I turn on the ignition, the dash display momentarily displays some letters, I hear a relay click at the same time in the back of the pcb, then goes blank. Pressing the start button has no effect.
What I have tried with no effect
Thanks
Justin
- Bypass ignition switch
- Bypass the seat and handbrake kill switches
- checked fuses
- cleaned connections to the pcb and checked for lose connectors etc
- shorted solenoid - engine spins freely
Thanks
Justin
