toolsinbox
- Jul 25, 2014
- 1
- 2
I have the Weedeater One riding mower and when you release the break to engage the drive there is a grinding coming from the area just right of ( when looking from the rear of the mower) the friction wheel. The shaft that passes through the friction wheel has a flat milled into it and passes through bearings I would suppose and other components to the right of the friction wheel. At first glance it would seem that what ever that milled flat is for has spun and possibly rounded it? The friction wheel is engaging and turning but the shaft with this flat just grinds in whet ever it is passing through and not turning the sprocket allowing forward movement. It does move in reverse tho? If any of you have any experience with this I would appreciate your input
