Good morning guys and gals,
I've been searching for info on the installation of washout ports on my Bad Boy. Does anyone have a suggestion on how many, the location, and which way they should be pointed? This is a 60 inch deck and I haven't been able to get any suggestions on a deck this large. I'm mowing about seven/eight acres about every two weeks and need a better system of washing than the one that I have. I see there are two holes already drilled on the top front, probably used for hanging at the paint shop. Would it be wise to use these? Thanking you in advance.
