Walk behind mower handle replacement
ghost1
I am replacing handle on walk behind mower model JA62 GXJA62V220658. Part numbers are M120194 and M110957. The replacement parts are making total length of handle shorter than original was, and now the push/pull cable (AM115556) is too long. Is it possible that the length of that cable has been updated also? It is an old mower.
ghost1
Found issue. I had push/pull cable anchored to wrong hole in handle.. Duh!!!!!!
