I'm working with a small engine mechanic, trying to get an old W5019 running again. He pulled the head and cleaned up the valves, which were badly fouled. He did a leak down test and it was holding to 90 psi. When he does a compression test he is only getting 25 - 30 psi. Does anyone know what kind of compression we should be getting with this engine? Thanks.
