- Sep 24, 2017
- 250
- 6,437
Sometime in the future i will need to repower my Mule, It appears the Honda GX390 should be a perfect fit..
anyhow, the original engine (FE290D-DS08) is equipped with a 14.5 amp alternator with 2 charging wires that both go straight to the regulator (6 pin), now my question is, if it a later date i swapped the FE290 for a GX390 Honda (i'm looking at one with a 18 amp alternator) would i be able to re use the old regulator?
The engine (gx390) also comes with a regulator, but i'm not sure if it would be compatible with the UTV, i've attached the buggies wiring diagram. and the GX390 http://www.smallenginewarehouse.com/GX390QNR.html
