It's a 727 with out front deckPlease tell us which model Grasshopper you're asking about.
You may be right but it seems to me if those are the reason It would vibrate all the time. I mow about 2 acres and it may vibrate for a minute or two and only the left steering lever.Loose transmission
Check the bolts
Something stuck in the pulley
Check the pulley
