Vented Briggs cap on Generac V-Twin
capouch
I'm trying to figure out a) just how this cap works and b) if there is a "fix" for its current behavior.
It's marked "Kelch Cedarburg WI" with "66" on one side of the rim and "2" on the other. Off a 19HP V-Twin on an older Generac 10000EXL.
Generator was stalling out; fiddling with the choke could keep it running. After playing around a bit, I discovered that (so far) it runs fine with the cap loosened, and every time I loosen it I hear a hiss coming from the tank.
Called Kelch, who are still around but apparently no longer in Cedarburg. They gave me the run-around and promised a call-back, but then did not.
It has a ball-bearing sounding something in the inside tube, and a tiny red ball on the very end of that inside tube.
Can anyone here tell me how it works, and whether it's "fixable?" capBottom.jpgcapTop.jpg
Scrubcadet10
Moderator
Staff member
B4325GS is the part number
So when i first read this i thought, "how expensive could a gas cap be, just replace it"
Ha.... $90 bucks.
You may see if another cap will work.
like a rotary 8935.
