Valve clearance
Ljh
What's the valve clearance on a 21hp briggs and stratton mower. Engine number 331877-0869-G5 for model 247.288853
Yes it in SAE thousandths of an inch.
sgkent
If you haven't used a set before be sure someone coaches you the first time on what is about the right feel. Basically you are feeling for light drag on the gauge that is the correct thickness. Some engines are done at TDC and some a specified piston drop past TDC.
Get a reasonable set. Like $7 thru Amazon.
