Michael_Gee
- Jul 4, 2017
- 5
- 14
Hey all,
I have a broken intake pushrod with my Intek/Briggs&Stratton 331777.
About 2 years ago I blew the head gasket. I fixed it and all was well until about 2 weeks ago when aluminum intake rod broke in half. I took off the head and pull the pushrod out, which had broken right in half. Everything looks good and value seats are fine so I was just going to order another lift rod BUT then I watched this (https://youtu.be/NM28FSoUGLQ?t=8m36s). He replaced the intake aluminum rod with a exhaust steel rod for added strength. I also thought this might be a good idea since maybe the steel would only bend next time (and you know there will probably be a next time with these engines) and not break in half like the aluminum. When it broke in half I was a bit worried that a piece might end up in the crankcase where with the steel, this chances of this happening might be lessened.
Other than maybe added cost, I can't see why Briggs & Stratton would not go with all steel pushrods but this also seems to be the norm with everything I've seen.
Anyone have any insite into this metal choice as well as any concerns with me doing this?
Thanks in advance,
Michael
Thanks in advance,
Michael
