7394
- Sep 5, 2014
- 84
- 4,693
My vintage B&S Flathead push mower is getting low on compression. Since it does not burn oil & plug is clean, I suspect the valves, in particular the Exhaust.
There is no valve lash adjustment in the conventional sense on this Flathead. Mow season is possibly close to over, So when done, I'll remove the head, rotate crank to .250" past TDC & see if the valves are closed tightly.
Likely not, so I'll have to remove each valve (only 2) & grind / file a few thou off the valve head (tip) & recheck, till I get .005 -.007 for Intake, & .007-.009 for Exhaust. Then close her back up. Flattys use a metal composite head gasket, so it is re-usable in most cases.. The side door to the valve springs & tips gasket will need replaced, & I'll just make a new one.
So I wanna find some torque specs.
