Tweel size - Hustler X-One
Flint Ridge
Looking to smooth out the ride. Michelin Fitment Guide says #14365. Order and go to install and the offset is wrong. Tweel instead of being spaced about 2" off the frame is about 1/4" away and in contact with the bracket for the fuel tank. Yes it is on correct with inner part oriented correctly. If I set in on backwards, the spacing is right distance from frame.
Call Michelin, go through with them Build Date 11/19, Model 936799... They say real Tweel #14365. But it doesn't fit. Well call Hustler
Hustler emails part #607447 - have no cross reference to verify what that is in Michelin numbers.
#14365 is certainly not the correct item. There is a #54411 also a 5 bolt with a -1.3" offset vs the 14365 +.7" offset. That is 2" difference moving the Tweel away from the frame.
Is the 5 bolt lug pattern setup the same on these two Tweels?
Seems like the #54411 may be the right model.
Anyone successful with this?
Thanks,
1slow5point0h
I’d probably just order a set of 1.5 or 1.75” wheel spacers and call it a day.
JimGurtner
Thanks,
Did the #54411 5-bolt with a -1.3" offset work? I am looking to get one also for my Hustler X-One also.
7394
I've read a few places that those fancy "tweels" can break on the spokes after the short warranty ends..
I'll stick to old school.
