Turf trac (Mtd) transaxle info needed
skinny
Ok I have a project I’m working on and I had thought I was going to use a transaxle out of a 16/44 turf trac but I might have a rotation issue
The donor mower was a vertical shaft motor but I have another from a horizontal I’m thinking same issue
I need to know the rotation direction on the vertical pulley on this transaxle also if there is another name or company attached to these
pic included
nearly all engines run clockwise from the top
The belt does not change direction so the tranny will turn clockwise from the top .
skinny
That sort of was thought when we chose the Mtd transaxle everything should go clockwise but now that we are in the test n check part it seems the vertical drive pulley is showing counterclockwise to be forward movement unless we have missed something
