STT61V-27KA (FD750V kawasaki).
Start engine, amp meter on the panel shows charge. Tested via volt meter, 13.4vdc. Turn pto clutch on, amp meter shows discharge (slight), and dvom shows 12.6-12.7vdc. After using the mower for a good hour or so, it will die--battery dead. I ASSume the fuel pump and other electrical components are pulling the battery down faster than it can recharge.
I suspect pto clutch is failing. Something smells of burning electrical after running a while, like a burnt up electric motor (I'm sure some of y'all know that smell). PTO clutch is real hot to the touch (and from my experience they usually get kinda warm). So on a hunch, I recharged battery and then with the engine off I did an amp draw test. Key on, pto clutch OFF (disconnected) it draws just over 1A. PTO clutch on, it draws 15A, so the pto clutch is pulling approx 14A. Resistance test on a cold clutch shows 0.5 ohm (IIRC should be about 2.5 to 3.0 ohm??). Resistance test from the pto clutch leads to ground is infinity on both leads. DVOM and test lead resistance 0.0 ohm.
Sound like a bad clutch? Windings shorted together internally I assume?
