Smokeeater
- Jun 12, 2018
- 17
- 59
The transmission in this mower isn't engaging was the complaint
- The drive belt is good
- The disengage is in the normal operating position, not transport fully out
So I lifted the back end and with the disengage rod pulled out the wheels turned as they should, when I push in the disengage lever fully to make it operate normally the wheels still spin and sometimes a grinding from the transmission is heard. I'm assuming the transmission is done?
