johnsplosion
- Mar 31, 2022
- 1
- 2
I have a Stihl TS 700 concrete saw in the shop. It came in after being ran without mixed gas, ie; blown up. I put a top end on it (piston, rings, new cylinder) and it it bogs down on the high jet. I did a leak down test and saw the second lever and crank seals were leaking so replaced those and it’s now air tight. It still bugs down and won’t hit the power and. It also sprays a fair amount of fuel back out of the carb and soaks the air filter. Starts and uses just fine. I have replaced nearly every part on this saw and nothing seems to fix the issue. Any advice or tips would be great. Cheers
