Troy-Bilt Self-Propelled Walk Behind Lawn mower
Model #: 12AEA29L011 Model: TB210
Hello, I needed to remove the screw that holds the spur gear on the drive shaft of my lawnmower, but I have not been able to. The mower is almost 14 years old, and the screws seem it's like they're welded on. I did spray some WD-40 on the screws earlier today and maybe in a few days it might loosen up. When I try removing the screw the drive shaft turns as well. I tried holding the drive shaft with pliers but it keeps slipping. Not sure if I should try holding the drive shaft with a pipe wrench or would this damage the shaft. If anyone has tips on how to to address this issue, I'd appreciate it. Thanks
