Check for blown fuse, also using 12v test light start at battery working your way to starter. How long time wise was it before you realized cables were on wrong?
Check for blown fuse, also using 12v test light start at battery working your way to starter. How long time wise was it before you realized cables were on wrong? Not long, when I put on negative cable to positive terminal it sparked and I pulled it off.
