I lost my key on my 2020 Troy-Built Pony 42 riding lawn mower. The advice I received was to bring in the ignition switch. I tried to keep track of how it was put together as I took the ignition switch apart. I was able to return with a key that worked in the switch portion. The switch came apart rather easily but upon assemble I obviously did not pay close enough attention and was unsure about putting it back together correctly. My question is there are four basic parts. A spring that fits in the center portion a circular plastic piece with three legs on one side, while the other side has a copper band that is about 1/3 around the edge. My question with this piece is where do I position this piece, it has three different locations relative to the on off portion of the ignition switch. The copper band connects with the fourth piece of the switch that plugs into the back of the ignition switch containes the wiring portion of the switch. This piece seems to attach in only one position and is almost triangular shaped in on the back with two "tabs" or ears that point up. With a larger tap pointing down. After assembly in the postition I presumed was correct turning the switch had zero effect. I obviously have to check the starter fuse under the battery? to confirm it is good yet, it had zero issues when I parked it. Though it is possible I blew the fuse upon assembly of the switch. I included a picture of what the idnition switch looks like.
