Troy-Built Pony (2008) Transmission check pluge
jamesstewart
Does anyone know where the Transmission check plug to check the gear oil level is located on my Troy-Built Pony (2008)
To my knowledge the unit is sealed and there is no way to check fluid level. Post the units model and serial numbers so we can see which tranny you have.
jamesstewart
Thank's guys for the info, the Model # 13AN77KG011- Serial #1G248H10320 - I guess if it is not serviceable I will have to make it serviceable. Again THANKS!
