Troy Bilt TB465SS Start Assist
acharvis
I used my weed eater and it was running rough. Before I went to start it again I adjusted the valves as I normally do on occasion. I went to crank it and the start assist wasn't working. It would pull straight through like there wasn't any compression. I checked everything that I had done and all was or appeared to be okay. Any thoughts? I checked all the springs I think on the cranking action and all seemed to work ok. Thanks in advance.
