Troy bilt Super Bronco model # 13WQA2KQ011
kenworth131613
Will not move forward or reverse. Just happened unexpectedly. Drove mower onto a trailer to transport mower to a different location. worked fine. started to back mower off the trailer & it would not move forward or reverse. Pin on back of mower is pushed in & lever is working on the transmission. any comments would be greatly appreciated.
Scrubcadet10
Moderator
Staff member
first i would check the trans drive belt is still on and routed correctly.
Scrubcadet10
Moderator
Staff member
and also check that idler/tension pulleys are moving when you press the pedal, #26
