Troy Bilt rider belt ?
bogdaN
Model # 13WX78KS04--Serial #1F040B70316,is this correct belt # 954-04060C.Thank you.
Correct deck belt for 2010 Bronco. Double check you model number because what you posted isn't a valid model number
bogdaN
there was more numbers next to it---317740.
bogdaN
Yes,U right that M. number is 13WX78KS011.I check Parts Tree and belt number ---954-0467A.Is that good number?Thanks Illinois engine.
That is correct for the front drive belt. if you are replacing the drive belt you need to replace both the front and rear drive belts at the same time. So you will also need 954-04208A. Otherwise you will through the sync of the belts off and it wouldn't operate the speed changes correctly.
bogdaN
Ok,i do that will order both of them.Again thank you very much.I live in Illinois before we move to Florida,so I know where is Beecher city.Dan
