Troy bilt pony deck
nbpt100
I'm looking for a used 42" Troy Bilt riding mower deck. It is for a Troy Bilt Pony Model 13WN77KS011 model year 2011.
I know parts are shared across MTD brands. The deck part number is 98304570A0638.
Can anyone shine some light on what other brands and model years where this part may be found?
Thanks in advance.
Go to Jacks Small Engines web page
Search for your mower then click on the deck page
From there right click on the deck belt and the blades and the deck pressing in the drop down parts list ( not in the image )
On each of these 3 windows there will be a list of all of the models that that part fits
Note, the deck pressing will have a different part number if it is a different colour which is why you also use the belt & blades .
That will not be the only models , just what comes up
If you click on the "other models: in the list and do the same you will come up with more alternatives.
A bit of computer work for you , but hey you have the problem not me .
Any cub cadet styled quick release deck will fit any MTD machine
The differences are the type of drag link at the front & the position of the rear lift mounts.
The front can be "fixed" by changing the front mount on the mower ( bolt on ) and the rear will require cutting & welding
nbpt100
Thanks Bert! Good info. I know there must be others in the MTD family like Bolens, Cub, Yard Machine etc. which will work the same. Your info about making mods is good too. Certainluy not the best option but maybe be if nothing better comes along. Knowing what other models will work is a logical starting point. Yes color will change the Part number and is a non functional feature for this need. thanks!!
MTD
13AN772S000 (2010) Ride on Lawn Mower
13AJ771S004 (2010) Lawn Tractor
13AJ775S059 (2010) Lawn Tractor
Troy-Bilt
13WN77KS011 (Pony) (2011) Lawn Tractor
13WN77KS211 (Pony) (2011) Lawn Tractor
13WN77KS011 (2013) Pony
13WN77KS066 (2013) Pony
13WN77KS211 (2013) Pony
13AM77KS011 (2014) Pony
13AM77KS066 (TB42)(2014) Lawn Tractor
13WM77KS011 (2014) Pony
13WM77KS211 (2014) Pony
13WN77KS011 (2011) Pony
13WN77KS211 (2011) Pony
13WN77KS066 (2012) Pony
13WN77KS211 (2012) Pony
13AN77KS011 (2013) Pony
13AN77KS066 (2013) Pony
13AN77KS211 (2013) Pony
Yard Man
13RM772S055 (2010) Lawn Tractor
MTD
Troy-Bilt
Yard Man
And there are a stack of Ryobi's with the same deck as well
Down here the Yardmachines have the Ryobi decks.
Don't know where they sell Ryobi ride ons .
nbpt100
They don't sell Ryobi's around here. MTD and Yardman yes!. There may also be some private labels like the TSC Huskey. I would not be surprised but I can not say for sure. Thanks.
Fish
Just do your searches using the part number MTD #98304570
