cityboy
- Apr 16, 2021
- 4
- 8
Troy Bilt Mustang XP 42 Starts then Dies.
First it would only run on choke and when I took it off choke, it would die. Then it would only run on choke for 1-2 seconds then die. I am putting a new carburetor in a few days. I removed the gasoline in case it was contaminated with water and put new Gasoline. Didn’t work. I changed the oil and put a new oil filter. I drained out that new oil to see if any gas was mixed in. Doesn’t look like it. I put a new air filter as well. I also put a new spark plug. I put a new battery as well. I am putting new belts in a few days. What could be the problem? Is it just a carburetor issue that will be fixed when I put a new one in? Thank you all in advance.
