New to the forum, so here goes. I have a Troy Bilt horse riding lawn mower won't stop unless it's in neutral. Brake is adjusted fine. Just wondering if it has an internal shaft that stops the Drive gears inside the Transmission. The shaft on the outside of the Tans housing uses a disk brake which makes think it does. Just wondering before i take the rear end apart. Appreciate any thoughts.
