troy bilt edger
speedy123
Hi
I have a Troy Bilt - grass edger trimmer
when I start the engine it runs
for less then a minute and then the motor stops working
please help me find the problem for my edger
thank you
Lets start with the model number so we can see what this thing looks like. It would be on a tag with the serial number, most likely starts with 21 or 41
speedy123
Hi
thank you for your message ,
were would I find the model number and serial number on the edger .
thank you
If you taking about a wheeled edger than the tag will be on the frame. If this is a handheld type edger than could be on the shaft or the blower housing of the weedeater type head.
speedy123
Hi
I have the info you asked
I found a number 25a-515-965-
its a Troy Bilt edger 2011
I only found on the internet a 25a-515-966- TBE 515
would this be the same as the one I have ,
hope this helps to find the problem with my edger
The 25a-515-966 is a 2007 model with a small 4 stroke weedeater type engine. If that resembles your engine most likely causes for your issue is valves out of adjustment, clogged fuel filter, or carb problems.
