Have a Troy Bilt 33" Combination Deck self-propelled mower that has stopped pulling suddenly. I don't have a model # because it is faded.
When I used it a few weeks ago it was fine. Tried yesterday and it will not pull. The only thing that was done in between that time is putting a tube in the right tire. No force was used to remove the rim. Just jacked the right side up, pull the E clip off the hub, then literally pull the rim off with no effort. Then put the rim back on with the new tube. Again, no force required.
I tried replacing the drive belt with a new one because it was very cracked, but that didn't help anything. I have tried all speed settings, and reverse. I can hear it clicking in each gear when the engine isn't running.
Is there anything I can do to fix?
Pics:
Pics:
6 new items by Tavis Curry
photos.app.goo.gl
