troy-bilt 19hp engine will not turn over.
funddy
I can turn flywhell past compression stroke and it will start. I am using a charged battery and tried jumper cables . Does this engine have a compression release .
Edwards saw service
The engine has too much compression for the starter to turn the flywheel. Pop the valve cover off and check the valve lifter clearance it should be around .030 to adjust the clearance make sure the piston is right before top dead center on the compression stroke ( both valves closed) the engine does have an automatic compression release for easier starting.
Edwards Saw Service in Glen Mills PA
funddy
Thanks for to info I will try that today.
funddy
I adjusted the valves and it did not correct the problem.
Edwards saw service
Do you still feel resistance when you turn the flywheel by hand other than compression?
funddy
N0 when I turn engine past the compression stroke it turns easer and will start first try. Thanks
jameswsr
What make is the engine? Most Troybilts use 19 hp ohv Briggs or kohlers it makes a difference.
funddy
kolher engine 19 hp
reddragon
is that .030....or .003??....big difference:eek:
Edwards saw service
Sorry .003 to .005 my iPhone auto corrected it. Sorry :-/
