tehinternet
- Aug 11, 2021
- 1
- 3
While pulling a drag to ruff up some topsoil, the Ariens 936085 was straining. While it pushing it hard, I did smell some slight hints of burnt belt, but would stop, backup, and give it another try to power through the area that was holding it back.
Immediately during/after this three things have started happening:
1.) Full throttle and any speed over about 75% vibrates from the transmission. I'm thinking the secondary pulley. It vibrates pretty violently.
2.) Reverse is suddenly 2x the speed it used to be, which is surprising because quite often it's always been weak on reverse.
3.) Reverse sometimes doesn't work at all and takes a bunch of trying forward/reverse all over again until it starts working weakly, normal, or crazy fast.
I went through the entire checklist video here:
as well as a PDF version with slightly more info. All check pass on it.
(secondary pulley is the one with the black cap on top)
I went through the cleaning under the primary pulley:
I cleaned out any debris I could found hiding above the plate near where the break pedal is and just general making sure there's no junk caught up in there.
The belt with teeth connecting both seems in good shape. No missing teeth.
The only thing I see odd is that the secondary pulley looks like it wobbles. The axle/bar that it's mounted on seems centered at the bottom/top, but as it spins it seems like it's oval shaped. I don't know enough about these to know if that's normal or broken.
Any idea on my secondary pulley theory or what might result in a really bad sounding vibration when in drive at full speed and reverse is all over the place?
Thanks.
Thanks.
